Good morning all! I just have a quick question. I've tried searching for an answer, but cant seem to come up with exactly what I'm wondering about.
This is in reference to a 657x, but I don't think it makes much of a difference.
I am still in the process of breaking in my motor. I know the best method of confirming the tune is correct is to slap new spark plugs in and run WOT for a bit then check the plugs. The problem is that I'm still in break-in and cannot go WOT.
Is there any particular and recommended method for confirming that a tune is at the very least okay during this process.
I started with the low speeds out 1 1/8th turn. The factory settings ask for 1 1/4th, but the 1/8th was done to compensate for the altitude I'm at.
From there I have been riding for 15-30 minutes at a time. Then pulling up to the beach and feeling the side of the motor and grabbing the top of the spark plugs. I recall hearing that the spark plugs should be hot, but not too hot to hold so that's been the main factor that has caused me to richen up the mixture. Does this seem reasonable?
In doing it this way I have noticed that the mag side cylinder is has been significantly hotter than PTO side. Due to this I have been very slowly richening the mag side carb. A question has occurred to me. Does the mag side just tend to run hotter than the PTO side? Or am I correct in thinking that this is a sign that the mag side carb is too lean?
Thanks in advance for your guys' responses! Carbs are one thing that makes me nervous and I never feel as if I know for sure that I'm making the right decisions with them.
