I got the impeller off and the ring out. There was a bunch of corrosion under the ring so I used a wire brush on a drill to get it off. While cutting the ring out I cut into the housing a bit in several places and made a few groves. Is there a way to fill those? Would marinetex work?Is it necessary? Also, is there a way to coat the pump so it will not corrode again? Would it work to powder coat the housing? How do I get the plastic nipples that go through the hull out of the pump?
