pop-off question
jlr40
Well actually a couple questions.
First, what exactly does the carb do when the pressure builds and pops off? Maybe thats a bad question, but what I do want to do is learn about the carbs.
I have a 97 challenger 1800, I pulled off one set of carbs, cleaned and inspected everything. Popoff on both mag/pto were 46-50psi. I realize this is high, but from what I read its a) w/in tolerance b) probably aftermarket springs installed on them.
Now the reason I am asking the q's, is I pulled the other set this wk/end, the mag is missing paint and corroded pretty bad, pto missing paint not corroded as much. Both are have been repainted. Problem comes is that the popoff on the mag is 25 psi and the pto is 38. Pto holds pressure fine, mag leaks .5psi/20sec. Not an immediate concern, but I am looking in to it. would the fact that the popoff b/twn the two carbs being so far from each other, impact performance on that motor? And does it matter that the other motor pops off 12 psi higher then other affect performance of the boat?
:confused::confused::confused:
Thanks ahead for anything that is going to clear this up for me.
"factory" carb tuning..
POP-OFF PRESSURE AND LOW SPEED JET
How do pop-off pressure and the low speed jet work together?
These two circuits overlap, although the low speed jet continues past 1/4 throttle where pop-off pressure has little to no effect. In general, if your pop-off is slightly too high, you can compensate by increasing the size of the low speed jet. The opposite is also true; if the low speed jet is slightly too small, you can compensate with less pop-off pressure. Once you get to the point where you think each is adjusted correctly, it's best to try varying the two to make certain you have the best combination. For example: If you have pop-off pressure of 30 psi and a 67.5 low speed jet, you should also try a pop-off of say 35 psi and a 70 low speed jet. To verify that you have the correct combination there are two things to test:
1. Throttle response should be crisp, with no hesitation.
2. Ride the boat at a constant 1/4 throttle opening for about 1 minute and then quickly open the throttle fully, there should be no hesitation and the engine should not show signs of being loaded up. If it hesitates, it's lean; if it's loaded up, it's rich. The first test is to check pop-off pressure, the second test is checking the correctness of the low speed jet size. Take the time to ride the boat slowly and thoroughly test your jetting changes. After a jet change, it takes the engine a few minutes of use to completely respond to the change.
When does it become necessary to adjust pop-off?
When personal watercraft come from the factory they have fairly high pop-off due to the fact that they also have somewhat restrictive air intake systems that cause the engine to generate very high manifold pressures; the higher the manifold pressures, the higher the pop-off pressure required to properly regulate the fuel delivery to the engine. As you modify or change your watercraft's flame arrestor to a less restrictive type you will most likely start to experience a lean hesitation caused by a decrease in manifold pressure. This change will require an adjustment in pop-off pressure to regain crisp throttle response. Because most aftermarket flame arrestors are less restrictive than stock, you will need to decrease pop-off to compensate.
The Super BN carbs that come from Mikuni America are already set up for performance applications, and come with pop-off settings lower than the carbs that come as original equipment. Pop-off pressure, (the regulator portion of the Super BN) is a tuneable component of the Super BN and works in conjunction with the low speed jet for good initial throttle response. The components that make up the regulator portion of the Super BN are:
1. Needle Valve, available in 4 sizes, 1.5, 2.0, 2.3 and 2.5 (Note: Some OEM
carbs have 1.2)
2. Arm Spring, available in 4 sizes, 115gr., 95gr., 80gr. And 65 gr.
3. Arm
4. Regulator Diaphragm
The arm has a limited range of adjustment; from the arm being level with the adjacent carb surface to being bent upwards no more than .040" (1mm) above that surface. If the arm is bent upwards too much, it can cause the needle valve to be held open when the diaphragm and cover are installed. If the arm is bent down, its movement becomes limited and may not be enough to allow the needle valve to open fully.
ADJUSTING POP-OFF PRESSURE
Pop-off pressure is adjusted by replacing the arm spring with one of a different gram rating. Sometimes, in order to achieve the desired pop-off pressure, it is also necessary to change the needle valve size; keep in mind that it's always best to use the smallest needle valve size to obtain the correct pop-off pressure.
MEASURING POP-OFF PRESSURE
You can measure pop-off pressure with a "pop-off" pump, available from Mikuni through your dealer.
CHECKING POP-OFF WITH A POP-OFF PUMP
1. Attach the pump to the fuel inlet nipple.
2. Cover, or in some way plug the fuel return nipple.
3. Remove the regulator diaphragm to observe the needle valve.
4. During testing, it is important to obtain consistent readings. To accomplish
this, it is necessary to keep the needle valve wet. Use WD-40 or something
similar to wet the needle valve. Note: Don't use gasoline because of the fire
hazard. Protect your eyes from the spray when the needle pops open.
5. Pressurize the carb with the pump until the needle valve pops open, being
careful to note the indicated pressure. Test the valve 3 times to assure an
accurate reading.
An indication that your pop-off needs to be adjusted is a lean hesitation when you open the throttle from idle; in the extreme, the engine may even die. It is much easier to detect a lean pop-off than it is a rich one, so it is wise to adjust your pop-off until you get it too lean and then back up until the lean hesitation disappears.
Note: It is recommended that you do not use too large a needle valve for your
application. Many tuners recommend using 2.3 or 2.5 needle valve in all cases. Actually, we recommend using the smallest needle valve that gives you the correct pop-off pressure for your engine. A 1.5 needle valve can flow the maximum amount of fuel that the Super BN can pump, so the only reason to use a larger needle valve is to obtain the correct needle valve and arm spring combination (pop-off) for your watercraft.
So that is why by boat dies when I take off from idle...
Been messing with the low-speed screw but seems to have made little difference.
