I need some help with pop off pressure. I made a tester but really dont have a full understanding of the process.
From my understanding, the needles must be exposed so I can apply WD-40 for a wet test. For my 97 XP the pressure should be 28-48 but both carbs within 2psi of each other.
I will hook the tester to my air compressor and to the fuel inlet nipple on one carb at a time. I use my finger to block the engine pulse and the fuel outlet nipple.
After slowly applying pressure I should see no air bubbles near the needle, but rather a loud pop after a build up of pressure.
Is this all correct?
