I have a '97 GSX that had a sbt engine installed in it last year. When I started the break in procedure this summer it ran fine for the first half hour. I parked it let it sit until it was completely cold. I took it out again for the second half hour of break in and it would just die on me. No beeps just dead. It would not restart for several minutes, I would wait a while and I would get an overheat light but no beeps. I will also get a low 12 volt light.
I have replaced the temperature sensor in the head. When I ground the wire from the temperature sensor with the ski running, it does not die or beep.
I can also attempt to start it on the hose and I will get a beep (single) and hi temp light (still cold has not run)
The battery is charged. It is at 12.5 volts sitting and goes to 13.4 when it is idling on the hose. I measured the resistance on the stator I get 1.3 on all three windings and no continuity to ground. The voltage is the same at the battery and the regulator. Looking at the regulator it looks like there are four burn marks on it. I do not get a/c voltage at the battery while the ski is running and it appears to be charging properly.
When the overheat light comes on I pull the seat and feel the engine and exhaust. The head is cold, the exhaust is cold the cylinder closest to the front of the ski is warmer than anything else, however I would not say that it is hot. I can hold my hand on it for quite a while with out any discomfort. I have replaced the beeper and it will beep twice when I install the lanyard. The pisser is working.
I can put the ski in diagnostic mode, I will get the loan and short beep to confirm diagnostic mode, but I do not get any codes when I then pull the lanyard and then hit the start button.
I apologize for the length of the post, I have checked the site, but I did not see any thing exactly like this. I really appreciate your help, I am at a loss. I thought about replacing the r/r but I don't want to keep throwing money at things that may not be the problem.
