Jetjon24
So I installed the fuel line I was missing with the jet, I found that some other small lines were cracked, and I replaced all of them. I then ran the engine and it sounded better, but when I pulled one spark plug cap while it's running it sounded the same, and if I pulled the other spark plug cap while it was running the engine died. So basically... I'm still running on just 1 cylinder. Would you suggest me paying someone hundreds upon hundreds of dollars to rebuild my carbs, buying new carbs off of eBay, or daring to rebuild them myself (with my limited experience)? Also, I am going to double check that I am getting a good spark in my bad cylinder, last time I checked I had spark.
