ocod
I thought I would start one thread and bump it when something comes up.
I purchased the sportster from 2nd owner on 7/16 that was downsizing and got it for $2800? I figured it was a good deal and if I had to throw 1-2 grand to fix I would be okay w/it seeing I got it for cheap so I think :leaving:
Since then I have spent every night working on maintence stuff and Sundays sea trial was less than impressive.
One motor would start and other wouldn't??
So far I invested the 50+ bucks for a carb rebuild kit which had a lot of extra gaskets left over.
I have a thread on it now but I'll ask/mention question here.
I followed this thread where in the first adobe file pic #8 there is a black rubber membrane that goes on side of where the small carb fuel filter is.
It looks like my model carb does not need that membrane per manual??
I used it anyways, but not sure if I should remove it(got manual after rebuild and installed carbs back :banghead
I found a gas leak from fitting close to N/S.
I think a hose goes from that fitting to the fitting near chokes butterfly squitter??
Other carb had a hose capped where the other one was leaking....
So choke may not be operational if assumption correct about hose looping b/w those two fittings??
http://www.seadooforum.com/showthread.php?t=3495
I would like someone to confirm please that I am indeed set up for premix.
PO said system was working but cable going to pump underneath carb is not connected. Gear still installed on inside of housing. not sure if there is supposed to be another gear on block side.
Still learning how the read diagrams from manual...
The in/out oil hoses at the block are still connected and so are the 2 tiny ones on ea side going to block.
There is a small hose that is connencted to the the top of oil tank that is pinched and not connected??
I checked the gas and the 35 gallons I just removed was NOT premixed
I put in new new plugs b/c last ones appeared fouled (black) despite not PO not premixing and non working oil pump??
Getting compression tester tomorrow.
I put my finger over sparkplug hole and get good suction and pressure against finger?? So I'm hoping I'm safe despite seeing some bubbles coming from bottom of cyl head :banghead:
Someone did a top end and gasket has black sealant everywhere and I dont think it was put on right b/c its sticking out??
The saga continues.
Open for discussions and opinions
The saga continues.
