FULL-THROTTLE
Lets talk two stroke oil pump operation,
I have twin 7878's:
1. Is there a method to check the oil pump when it is out of/off the engine?
2. What kind of oil pressure does the pump send out to the intake?
3. We all know you will use considerably more oil if you go to a straight premix, but why? does the engine & oil pump lean out the mix at higher speeds.
Theoretically if you are running at 40:1, with the oil pump you should use the same quantity of oil if you are running a premix in the fuel tank. Slow speeds means less fuel & less oil, higher speeds means more fuel & more oil.
4. How many people have had an oil pump go bad? therefore when should you replace them. I would prefer to change mine before they go bad. I know bad oil pump means, broke down, overheated, siezed, expensive, and really bad day.
I think this thread will help many understand the oil injection system and how to maintain it.
Thanks,
I have twin 7878's:
Thanks,
