Oil pressure sender / sensor socket size?
tima4444
Hi all, first post on this forum!
I'm getting intermittent oil light and limp mode on my 2007 Speedster 215 HP 4TEC. Checked oil pressure it's 90 psi at cold start/idle, 36 at hot idle, 60 at 3500 rpm and 82 at ~7600rpm. I'm thinking first I'll change the oil pressure sender/switch at the back under the intake (1 wire connector) to begin with. Anybody know the deep socket that I'll need? It's in a PITA location.
Replaced the oil pressure switch, solved my issue completely. For the record, the 13/16 spark plug socket is a just a tad too small, the socket size is 21mm. Thanks ski-d00.
