ChrisV
I was working on cleaning my carbs and noticed one of the little OIL Injector Lines is cracked. I am talking about the tiny lines to the injector needles not the big main feed lines from the resevoir.
I also notice oil is kinda everywhere in the engine compartment...
So...
1-What are the inside diameters of the both the smaller and larger lines
2-Where can I buy some new oil lines, both the larger and the smaller lines at?
3-Does it have to be any kind of special material or will just any clear tubing work???
Also on the smaller lines, can I just remove the clamps and replace the tube, leaving the banjo fitting and the injector in place and just use a zip tie on it to secure new line, or does the replacement line have the injector and banjo fitting already attached???
So...
