hi again everybody good news i got it fixed and i didnt have to pay anyone ,my friend and i figured it out.....first we bleed the gas lines from all places we could.....as the gas didnt smell like gas ...it was watered down (cheap fuel) explains why it wouldnt stay running and as far as the oil lite going off >>>when i took off the fuel filter(same as oil filter in a car same idea)only difference is a sensor on the bottom with a wire that plugs into.the fuel filter had water in it as well.....which i emptied and refill with good gas ,stopped the red lite from coming on and buzzing .so we kept purging the lines and took plugs off and dried off, then put couple drops off gas into each cylinder put the plugs back in and it fired up right away and no problems since.thanks for the replys i got back and hope this helps out if you have the same problem as i did
tattoo:cheers:
tattoo:cheers:
