Oil injection pump no good anymore?
Stacks
I cannot get oil to prime through the pump i to the injection lines. Last year I replaced the injection lines and primed it successfully.
Had the motor rebuilt and cannot get oil to prime through the lines no matter what i try. I am running a battery drill in reverse with the plastic adapter in the chuck of the drill, bleeder valve is cracked and throttle is wide open. I let the oil gravity feed to the pump from the line.
I suspected maybe the inline filter was clogged so I bypassed it to see if i could get oil through the pump. Still not getting anything through. All that happens is when I spin the pump air gets in the lines. I know its super rare for the pump to fail but i am kind of stumped on this. Unfortunately i really cant do much with the ski until this issue is resolved. Am I doing anything wrong or did the pump malfunction?
attached are 2 pictures. The first is with the throttle at idle and the 2nd is wide open. I can add more pictures per request. Let me know, thank you.
With the bleeder open,,is oil coming out of it?,..if no...maybe the vent is not working?,,,try loosening the filler cap.
I mean.that before you try to prime,,,the pump must be bled first,
whoops more oil leaked out than i suspected when i removed the crank feed line from engine while taking it out. i added some oil in and what do you know? the lines started to fill when primed. silly mistake but thanks for the feedback anyways. issue has been resolved
