I just did my first oil & filter change in my 08 Challenger 180. Easy enough but my question to the group is this:
Is there a faster way to suck dry the sump? The drill pump is slow as hell! I've seen a pump attached to a catch container and I've seen the vacuum canisters you pump by hand. All of these solutions see to suffer the same drawback, a small inside diameter tube that is needed to snake down the dip stick tube.
Will a higher volume pump make a difference and speed up the process? What do the pro's use to change the oil?
Thanks,
Ted
Thanks,
Ted
