triad_cowboy
1996 Bombarier Xp
Here the problem... It will crank and idol fine.....in or out of the water..
Thought the Pop off pressure on the dual carbs was the problem. Took them off and had it reset. replace with new gasket. Same problem.... will take off and go immediately back to idol. Last test run it develop a new problem/warning... a alarm sounded off barely. I cut it off for a minute, started it back up no buzzer hit the throttle and same results with the warning buzzer.
This leads me to believe that the buzzer I hearing is a safety deal for the premix oil system?
If so.... I want to by pass the premix system and mix my own gas...
I will need to know how to locate and correctly by pass the safety buzzer... and the ratio for the gas mix? Also I will need help on how to by pass the system correctly.Any help or suggestions will be appreciated:hurray:
