Oil by pass help
triad_cowboy
1996 Bombarier Xp
Here the problem... It will crank and idol fine.....in or out of the water..
Thought the Pop off pressure on the dual carbs was the problem. Took them off and had it reset. replace with new gasket. Same problem.... will take off and go immediately back to idol. Last test run it develop a new problem/warning... a alarm sounded off barely. I cut it off for a minute, started it back up no buzzer hit the throttle and same results with the warning buzzer.
This leads me to believe that the buzzer I hearing is a safety deal for the premix oil system?
If so.... I want to by pass the premix system and mix my own gas...
I will need to know how to locate and correctly by pass the safety buzzer... and the ratio for the gas mix? Also I will need help on how to by pass the system correctly.Any help or suggestions will be appreciated:hurray:
there's no buzzer for the oil system, only a warning light when the oil level is low. the beeper buzzer is overheat, your sender may be bad.
your problem sounds carb related, did you clean/rebuild them completely?
ok... where is the sensor located so I can temporarily by-pass/disable it to see if that is the alarm I am hearing and if it related to my other problem.
the sensor is located on top of the head it is just a little tempature probe you could pull it off and i dont think it would sound, but thats not going to fix your problem, will just stop the buzzong
