mookerblu
So my cousin and I were comparing our Sea Doos today. Mine is an '07 RXP and his a '08 RXT. His side vanes (used for steering) will move up and down depending on speed.
This is an excerpt from the manual describing it:
Models with Sliding Side Vanes
(O.P.A.S. System)
When engine is running at approximately
75% or more RPM, the side
vanes are automatically raised to upper
position since they are not required
at that vehicle speed range.
Between 30% and 75% engine RPM,
side vanes are gradually raised from
lower position to upper position.
When throttle is released and engine
RPM drops, the side vanes are automatically
lowered thus assisting steering
control
________________________________________________
Sooooooo.... I noticed when riding his, that his will steer A LOT better and I'm jealous
Looking at the parts diagrams, it looks like his has a spring and mine doesn't. I'm wondering if anyone has converted their "fixed vanes" into "sliding vanes".
The Spring is the key part and standard on his....
see part #20 on this http://partsfinder.onlinemicrofiche.com/seadooforums/Seadoo_oem/Seadoo_PWC.asp?Type=13&A=164&B=17
and on mine it has the spacer instead of a spring keeping them raised at all times.... part #22 http://partsfinder.onlinemicrofiche.com/seadooforums/Seadoo_oem/Seadoo_PWC.asp?Type=13&A=149&B=18
do you think its possible to just buy the spring and install it in place of the spacer? They look to be the same size.......
(O.P.A.S. System)
control
