not enough power
wi manuel
i have a seedoo o4 rxt supercharged and want to wake board behind it but it has trouble pulling me out the water. Is the motor powerful enough or do i need to up grade the propeller.I weigh 85kgs
well i am 215 pounds and i had a GTX DI 2003 with only 130 HP that pulled me up with no problem. Your boat as 215 i dont think you need to to any performace up grades just practices getting up some more.
Vts?
When your ready to be pulled up, make sure your VTS is set with the nozzle in the down position. This will allow the nose to stay down until you gain some forward momentum. Then you can trim it out a little after your get on top of the water............
