"light test" the white wire at the coil, while cranking over motor. If it lights up, then clip your plug wires and try again. If no spark still, then replace the coil. If the light tester doesnt light up, then inspect the stator assy and/or check fuses and leads/grds conditions. Think also for that year, there was a little black wire from the ebox, that also needs to be connected to the neg side of battery.
