Just finished replacing the grey fuel lines with black automotive lines. Figured maybe something was clogged in the gray lines that wasn't allowing fuel to get to the carb. Seems that none of the grey lines were blocked (not mad cause I had to do the job anyway) I took off the fuel filter and emptied the gas out of the bowl, then cranked the engine 5-6 times for 5-10 seconds each time. Removed the fuel filter housing and no fuel in the bowl. It seems as I am having no fuel pressure to suck the fuel up the baffle. Where should I start with this. By the way, took off the selector and cleaned it out with carb cleaner. Incidentally, is the fuel on when the selector knob is loose or tight? It doesn't seem to line up very well with the icons and as I turn the knob it goes from tight to loose to tight to loose...you know what I mean? thanks
