Thanks for the advice, guys! prop and wear ring look good, previous owner replaced them not long ago due to gravel ingestion. I plan to change the impeller oil once it's running. Do you recommend the genuine Bombardier impelled oil, or is there a better or less expensive product out there? I've got a dealer close by, so picking up the correct oil would be easy. I'll tasked your advice on the lines... It's cheap enough, and just a weekend project. Doesn't look very difficult to replace them all. As per the tech manual....Those little oil lines have to be bled out, right? I've seen some folks say to run mixed gas 'til you know the pump is working... what do you think of that?
Took a trip over to Helena, Montana Friday, and I was kinda surprised to see that almost all of the lakes on the way are still frozen over! Coldest spring we've had for awhile... Glad I haven't drained the antifreeze from the boat, yet! Anyways, I've got a month at least until the water is warm enough to try this thing out. Can't wait!
