krazybob738
Hello all I just bought a 95 seadoo speedster with the twin 657 motors I have a few problems with it when I picked the boat up the engines ran I brought the boat home dropped it in the water took it for a run and both engines ran made one lap around the lake the left motor died and the right motor would only push the boat about 10 mph I think this one needs a wear ring the left motor has wet plugs and both kinda bog at full throttle I was thinking probably a carb rebuild would be an order but this left motor just wont start the other thing I noticed is both engines are connected to one battery should I connect a second batt? the plugs also look pretty bad I am going to pick up new plugs in the morning I think maybe this engine is flooding out. also the lap around the lake took about 10 min and when I pulled the boat out of the ater I noticed some water in the engine compartment I turned the bilge on and if I had to guess I would say about a gallon of water came out of it maybe two gallons but not more then that how would I go about finding this leak? any help would be great thanks an advance!
also thought I would mention that both engines have 140 psi and spark. hypothetically speaking if something is majorly wrong with this engine and I wanted to put something bigger could I? and if so what? I don't wanna buy a whole other boat to make something work is there anything plug and play? maybe the 787 or something?
Robert
Robert
