Greg Moore
06 RXP, SC fried a few hours after a dealer did 100hr washers. Impeller bearing went, prob not dealers fault since they only did washers and turns out (through engine tear down) this girl had failed ceramics in past.. I bought it dead so works for me..
Question is about bearings. I picked up a supposedly 200hr rebuilt but unused since rebuild SC.. It's a newer version but same size (has different back case number and an oil hole between the o-rings the 06 doesn't have) It certainly looks unused since rebuild, it's spotless all round with no polishing on gear teeth yet and a spotless shiny intake area..
Spinning this by hand to me feels tight. It's dead smooth, zero play in any direction and a slight bearing race sound. It feels like there is preload on the bearings. Have never done one of these SC's but have played with a turbo a few years back. If you spun the turbo by hand it would take several seconds to spool down. This takes just a couple to come to a stop.
Do the bearings in these things have a slight preload on them? If so I'll trust this was built right. Or does a fresh rebuild spin for ages when flipped by hand before it stops turning? I'd hate to tear down a pro rebuild for no reason but would also hate to fix all the motor bits and throw on an SC that will also dump a bearing a few hours after use.
Thanks in advance!
Thanks in advance!
