Hey Everyone,
New Guy here saying hello and hope that everyone is doing well! I really appreciate everyone's knowledge from what i've read so! Recently I purchased my first PWC (not a first time rider) and now have a quick question. I did the research on what to look for and came across a well maintained 97 GTX with 50 hours for cheap(unfortunately was too far from water for a test drive).It ran very well with hose and for under 2K, you would have bought this ski too having seen it's condition. Ran great right off the bat, in water, then bogged down intermittently at high RPM, and eventually(in little time) got worse at lower and lower RPM's. I then turned to SEADOOFORUMS.COM for help and quickly learned that the grey fuel lines had NOT been replaced and carbs were filthy. I replaced some fuel lines(doing the others soon!) and cleaned plus rebuilt both carbs.(Have always insisted/loved doing EVERYTHING myself-engineering background). The outcome was awesome, with top speeds faster than i could have imagined-that 787 is powerful. Now, the only difference between before and after the carb rebuilding is that it doesn't start right away. Today i had to give it a few pumps of the throttle to fire up but runs perfectly once started. I'm hoping someone has some insight as to what i may have tinkered with improperly or a quick fix! Thanks@!
