New Hardware update kits for carbs
I installed these about a month and a half ago. They worked great! Just now getting pics up.
Getting the old screws out was a major pain.
The heads stripped. Was able to get most out with a hand impact screwdriver. But this one was the hardest. Had to take a torch to it and turn it in 1/8 increments with lots of pb blaster.
After all that I forgot to take pics of the new ones installed. They worked great and I recommend them!
Thanks JSG.
Hey goodies you still got these kits??? I have been pm'ing but no answer. I need a set!!! Bumpo
Thanks guys! I got in touch with him... Soooo if you need some maybe now is the time to message him. These screw kits are AWESOME!
As mentioned on other threads here the phillips-type screws are actually JIS as indicated by the little indented dot on the head. Acquiring the proper drivers (available at many sites, I got mine on Amazon) will make working with these screws much easier, even if the goal is to remove and replace with something else. Since using the proper driver I have not stripped out the head of any JIS screw (now I went and said it). A cheap substitute sometimes works by grinding off the tip of a phillips screwdriver of appropriate size so the driver does not bottom out in the screw head.
Love this idea! I did this to my carbs about 2 years ago while I was working for a bolt supply house. I also replaced the little screws that hold the seat and needle arm with socket screws. No more beating your head against a wall over the little demon screws. I swear if you look at them the wrong way they strip.
Do the 587 and the 657 use the same 38 carb? Looking for a set for my dual carb 587 setup!
