Hello all, 1994 Seadoo GTX 657X twin carb, After going through the carbs, cleaning the filters (very small amount of debris in the filters) and setting them back to the factory recommended seadoo settings from the link in the carb rebuild sticky 1 1/4 low speed and 3/8 high speed the ski starts and runs (out of water so didn't run it long) but needs a touch of throttle or it will die out. Do I get it in the water to see after running it for a bit if the issue remains or do I make an adjustment to the low speed screw or throttle setting? Guessing throttle setting adjustment would be the last adjustment not 1st? As always thanks.
- For what it is also worth incase it has bearing on recommendations, both carbs tested good for pop off pressure (31/29) and pressure/ vacuum held.
- Also in making adjustments to high or low speed screws what is the general rule? I understand in to lean it out and out for richer but when trying to adjust if necessary and diagnose idle, ramp up or high speed performance challenges what makes you determine it needs to be opened more or close down more? (hope this questions makes sense)
Thanks
Thanks
