Need to check wear ring and pump
cobb5797
Guys..How do I take off the reverse flap? I took springs off and got the left side bolt out but what about the right side? When I take bolt out its still attached and I don't want to force anything!
10mm socket or wrench top and bottom, remove nut and bolt, pop out the linkage with a flat blade screwdriver. You probably need a service manual, you can get one on this site if you join as a premium member or just google for one.
Lou
Hmm ok..it looks like it has a sleeve that goes through and that is throwing me off. So once I take bolt out I can just pop it out? Just clarifying fellas
See how it looks like a sleeve goes through. ..I take the bolt out and the linkage acts like it's still on a bolt
