Need some 94 gts oil line help
offgrididaho
I have a 94 GTS single carb 587 ski I bought at an estate sale. Its been sitting 15+ years, covered, in a heated garage. I replaced the oil, put fresh gas in it and it fired right up. I took it out on the lake and it blasted to top end really quick. I decided to rebuild the carb and it needed it, rubber diaphrams were stiff. In the process of getting the carb off I boke one of the tiny oil lines (3/32 ??) and both need replacing now. I am also going to replace the feed and return oil lines. I think one of those is 5/16 and the other is bigger so ??? size?
I also replaced all the gray green goo fuel lines and on/off switch. They were bad too.
Can someone tell me the 3 sizes I need to order?
Can I replace the oil lines without pulling the pump off?
Is there a video or "how to" on replacing the oil lines and bleed them?
Can you tell me how many feet of each line?
Thanks....... I'll post pics later if it helps.
I am new to this and tried searching but cannot find the larger line size of how to replace the tiny 3/32 lines. I don't want to break the fitting and they are stuck on hard.
8mm to the pump, 12mm to the rotary valve and 3/32 from the pump to the intake or buy the 1500mm of genuine oil line for pump to intake from BRP which I prefer. I have yet to see the 8mm or the 12mm lines needing replacement. Where did you buy the carb rebuild kit from? You don’t need to pull the oil pump off to change the oil lines. If it’s the original small oil lines with the metal clamps I’ve squeezed the clamps gently, once the clamp is off I will cut gently along the side of the oil line on the fitting to make it easier to pull off.
You don’t need to replace any of the oil lines except for the two small 3/32” ones. None of the others ever go bad.
I went to mikuni and they had a link to order from them on Amazon for the kit. It was in a mikuni blister pack.
OK I picked up the 3/32 tygon from ACE hardware small motor shop. I could not find the clamps. Do you have a link or source to the tiny clamps. I dont want to run zip-ties.
So i guess the mini ear clamps for the 3/32 lines. I will also replace the oil filter. Do I just bleed the lines until no bubbles? I have read here that the 1/2in oil line fits loose. Would a 7/16ths ID line work better? I want to order the larger two lines and have them here just in case. I will hold off on installing for now.
I changed the impeller res oil too. Anything else I need to do? Any vidoes on replacing the 2 tiny oil lines?
Thanks for the help......
No source for the clamps, I always use zip ties. The small oil lines fit so snug that there’s no way they are coming off even without zip ties. To get them on I hold the end of the hose with needle nose pliers and start putting tjr hose on, on a 45 degree angle. It helps to heat the hose with a hair dryer a little first. I would order the larger lines from BRP, I would have ordered the smaller lines from BRP as well. And my reasoning for that is, they fit the way they are supposed to fit, they are made out of proper material that will last 20 years plus. I know tygon is a go to for a lot of people but with all the made in China crap I like to have a 3rd party (BRP) doing some due diligence. If not ordering from BRP order metric ID hose.if your changing the 12mm lines to the RV they don’t need to be bled. For the 8mm hose to the oil pump, take the hose off the filter side closest to the pump, hold the filter vertically but beneath the level of the oil in the tank for a second or 2, then put it back on the remaining hose to the pump, then open the bleeder screw on thff red oil pump for a few seconds. Then start the machine, reach down and pull the oil pump lever to full open while the machjnff ed is idling to fill up the new small oil lines. Make sure the mark in the oil pump lever is aligned with the mark on the oil pump. Did you pressure test the come after changing the oil? If not, might be a good idea to take the screw out after riding and check the oil for level and water after riding
OK thanks. I dont know what the oil line marker is?? Any pictures? I will try to look that up. Is there an adjustment?
I was able to find the clamps. The OD of the tubing is 4.5 and I found 4.5-3.5 clamps. I need to measure the tubing on the fitting once I get the old off to make sure these clamps will work before odering.
https://www.huyett.com/hc2e-0045-ssb
IMG_4001.jpegThis is from my 95HX, well up till last week. The cable forked to the oil pump lever, you can see the mark in the lever and in the pump, they need to be lined up.
You don’t need the clamps, just high quality zipties like Thomas & Betts.
OOOps.... I just went to the hardware store and got some small zipties. I put 2 on each hose fitting, one as a backup. Its going to be good enough for now. Ive been working on the ski for a week and Im sick of it for now. I have real bad arthritis so its one hour at a time, then rest.
Which way does the oil lever go, under or over? Im guessing its the way I feel spring tensoin and NOT no tension.
One last question. I see 3 big oil lines coming/going to the motor. One huge one on the left side on bottom all by itself that feeds back into the top of the oil tank and two medium size lines going from bottom of the oil tank to the carb. I know the one with the filter is the incoming, what are the other two? And which is which?
Yes oil arm has to be under spring tension.
Large 12mm oil line from the bottom of the tank on the intake side goes to the lower cases to supply the rotary shaft gear with oil. 12mm oil line on the exhaust side is the vent for the rotary gear to the top of the tank. 8mm from the bottom of the tank with the filter feeds the oil pump.
Well put it in the water and tested it out, or tried to. Got about 50 feet and it started chocking and dying and quit. I kept trying to start it. The only way I could get it to catch at all was to pull the choke and then give it throttle. It would start and die.
Not sure what I did wrong with the carb but I was very careful to do each step right. The only thing I can think of is that the one gasket it said "not used on 38bn" was needed. The #1 gasket that points to 2 gaskets. I did not use the bottom as it says not used on 38. What a nightmare!
They should have kept the instructions seperate instead of mixing them, it was very confusing. Now I have to do it all over again and I have no idea what I did wrong. See diagram......
Just follow the carb rebuild sticky, it is pretty much step by step.
Well some more news. On a hunch it seemed like it was starving for gas on the low end. I adjusted the low jet out 1 turn and it ran fine on the ramp up to half throttle (couldnt go higher without damaging the ski/trailer). I zinged it twice and it did not die. BUT, in the process of doing that I noticed a lot of oil on the left side channel. Its injector oil. My tank is down about 1/3rd of an inch. I looked all over and cannot spot the leak. I felt around the lines going under and they are dry at the connection. I don't see the tank leaking, but some places I cannot see.
Where and how do I search for the leak?
Should I turn the low jet back in and count turns? Its really hard to get to.
Also there is about a 5-6 inch air bubble on the top of the oil line where it goes up from the motor and returns into the top of the tank. Is that normal?
Clean the hull and put clean paper towels under al the hoses and you will find the leak.
Carb adjuster screws should all be set to stock settings on a stock engine with stock air-cleaner.
That hose to the top of the oil tank is just a vent so it is only as full as the tank level.
OK, thanks.
So the low jet goes out to richen and in to lean fuel, its a fuel screw not an air screw correct? I read it can be from 1 1/4 to 1 1/2
Any tricks for cleaning the hull?
Yes, they are a fuel screw. In and seated is closed "lean" out is adding fuel "rich".
Castrol SuperClean and an electric pressure washer.
OK thanks.
I have a feeling whats leaking is the big return oil line under the muffler. Is there a way to get to that if it needs replacing? I can just barely get my hand on it, how would you get a clamp on the end?
OK, I spent half the day drying the oil up with rags. I see a thin layer on the left top side black motor bracket. I see a thin sheen on front of oil tank by the two ingress fitting on top (maybe I overfilled?). I doesnt seem to be leaking when not running. I think! I replaced the 3/32 oil lines, one had broke off. Could it, the 3/32 line, have leaked while it was broken off and filled the hull with about 4oz of oil??? Oddly, the oil is on the opposite side of the engine in the hull. I dont have any oil on the 3/32 line side. Maybe it dripped on the motor mount and ran down the left side???
OK another update. No oil leaked overnight. I just took it for a spin on my lake. The low needle was out 2.25 turns. I set it at 1.5 turns out and it was falling flat down low when cold. Improved a bit when warm but still had a bog down low. Up high it ran great. So I stopped and set needle to 1.75 out and it ran better but still a bit of low bog when punching it. At 2.25 it runs fine down low. So Im guessing something is wrong with the carb. I am also guessing I cannot run it all summer at 2.25 turns out on the low? No oil in hull when I got back that I can see.
If I am going to do the carb again I want to replace all the parts, needles, jets etc. I bought 2 kits just in case I broke something and I have all the parts except the 2 little black rubber plugs with disks. I need two more of those. Is there a place where I can buy one off parts that I need?
How can I find out what jets I need to order?
Thanks again
Forgot to ask, is there a place where I can buy a new carb jetted correctly? And who sells base gaskets for the 38bn? Amazon sent me the wrong ones?
Low/off idle issues are typically caused by the little bypass holes not being clean. I show how to clean them in the carb sticky.
You don't need to replace jets unless they look bad.
On a rebuild I replace all gaskets, seals, needle and seat, needle arm and pin and fuel pump check valves and rubber holders.
