Tokk boat out today having a blast, then starboard engine started stalling. Would start back up and die again at 4k rpms.... Thought maybe fouled a plug so changed them just to see. Same problem. Then oil light came on but it was full when i put in the water hour earlier. put it on the trailer and headed home. Noticed a little oil in the back of engine compartment.
Went thru it and found the oil line going to the oil pump had fallen off.
Now at the end of the line with the in-line oil filter I have a clamp and a brass 90 degree fitting. Does this fitting just snap in? Dosen't look like it's broken. Or in the oil pump end is there a rubber gromet or something? I have found the hole hanging upside down but it's in an extremely tight place and it dosen't seem to want to fit back.
How do i fix this????
Thank you in advance
Matt
Matt
