I have a 1998 XP Limited I purchased about 5 months ago.. The throttle shaft on one of the carbs needs to be replaced. I thought I could get away with just replacing the plastic bushings but even with the new bushings installed the shaft sticks so I need a new shaft was well. My problems are:
1) the carbs on the ski do NOT match the carbs on the parts diagram for the '98 XP. It matches the diagram for a 1998 GTX Limited (and the 98 GSX Limited). So, I am OK with the switched carbs (my guess is SeaDoo switched the carbs during production on the XP Limited at some point during the year and there is only one diagram). But I still have a problem because
2) there is no part number for the shaft in the diagrams for the GTX (or GSX). Below is a pic of the parts diagram. I need part #21. Notice the list goes from 20 to 22. What gives with that?
Actually I only need the shaft...the pic in the 98 GSX and GTX diagram shows the round part that the cable activates as part of the shaft but on my carb this is held on by a nut so the shaft I need is threaded on both sides.
So, Where can I buy this shaft?
