Need Flush hose for 95 sportster...
jim9078
New to the forum. Sorry if this is in wrong place.
I am trying to find the external hose that clamps to the fitting under the engine compartment cover for flushing the engine. Thanks for any help.
Not sure if ours are different but mine is like a end of a hose just screw the hose into it.. I use a T fitting with shut off's & a short piece of hose off the T fitting/long hose to tap so I can turn on the water myself..:cheers:
connection hose for 95 sportster engine flush port
The fitting is on the hull of mine takes a special clamp. The parts diagram (this site, 95 sportster, cooling system) indicates the fitting that is on mine is supposed to be there. It is a restrictor shaped like a pencil with small openings in the sides. I had the extension hose but it disappeared :-( I amy have to find a way to redesign a new connector. Thanks for your input.
