Don't give up
Seadoo 1800 twin 787s. No spark. Tired of messing with it. I'm looking for a good mechanic somewhat local to Ocala Florida. I've done all I can do. Just spent another $1000 to replace MPEM. Still no spark. Battery is good. Connections are good. I have not checked the stators or tested the wires coming out. Someone told me how to make a test plug to put an ohmeter on but I forgot. I'm getting burned out on this thing and just want someone to look at it and tell me what to fix. I need help
I'm sorry to hear. I'm in Houston and nobody here wants to work on my boat. Once I found a great shop in a near by city (I'm in Houston)they did great work, but they closed a year or two after I found it.
Looking at the shop manual (Sportster/Challenger 1999 1800 share it) to test the trigger coil, it says there is a harness to test, and you connect to white on one side and Black/Yellow on the other. They use a pigtail to test so I can't be sure that the colors are the same on the boat. Resistance should be 190-300Ohms
Your spark plug cables start at the coil. Long ago when I was troubleshooting a similar issue (and it was the coil that was bad) I put an LED between ground and the small cable going to the coil. as I cranked the engine I could see the LED flicker when the spark was being "requested" of the coil. That may help you determine if it's the spark coil or the trigger coil. It probably would take you 30 mins tops while having a beer to disassemble the black electric box and hook up the test.
If you determine it is the stator, maybe you can find a local jet-ski shop willing to swap it. I would suspect the engine has to come out, but someone else can talk to it.
If it's the coil, It is a PIECE of cake to swap, and in fact you will have done 1/2 the job by opening the electric box.
Good Luck!!! Don't loose faith, they are fun to run, but it also has to be somewhat enjoyable to work on it for you until you get it running well. otherwise it's a pain the @$$ (unless you find a good and trustworthy mechanic. They are not unicorns because I have seen them before, but they sure are HARD to find)
