mpem interchange
You could check the "parts" link and compare part numbers to see which will work with your doo.
Karl
Your ski is the last year of the old style MPEM, and also was a dess capeable or/and a programable module, with 7 programable slots in the ROM. meaning non-dess, or
you could program into the module SEVEN different key embedded codes with a programmer, IF you chose to do so. If you were to buy a new 278000822 mpem, the
third wire required for a dess post is capped. You can use a standard two wire post
if you desire non-dess. Another 720 MPEM is a 278000423 non-dess module. A two
wire non-dess safety lanyard post is used with that module, and that will also run
your accessories electronics as well. Same E-box. Bills86e
