seadooNY575
My 96 sporster has been sitting for a month and today it would not start, it only turned over once and then nothing. I took out the plugs to crank it and attempt to push out any excess oil/gas and or moisture. Put them back and again it turns over once and then nothing. The weird thing is that if I place either of two plugs and leave the other cylinder with out a plug it will crank until it starts. Doesnt matter which one, as long as one cylinder had a plug and the other didnt, it will start. OR I could thread the second plug in just a couple of turns and attach the wire to it and it will start, as long as it is not screwed in completely. Whats is going on? P.S. dont know if it is related but the last time I took it out the cooling system must have gotten clogged because hardly any water was coming out of the pee hole, however I did reverse flush it once I got it out of the water and it seemed to be clear after that. HELP!
