OK, a while back I was concerned that maybe my oiling system was not working up to par...
As an experiment (I LOVE experimenting!:cheers
I marked on the oil tank where the oil level was, and proceeded to fill 2 5 gallon tanks of super unleaded. Just in case the oil system was weak, I mixed 80:1 oil in the fuel canisters. I then filled up the fuel tank and have spent the past 2 weeks running as much fuel off as possible.
I figured that I would burn off 10 gallons of gas, then measure how much oil it takes to fill the oil tank back up to the line I drew 10 gallons ago. I have only burned off 5 gallons so far, but notice that my plugs are wet with oil (no smoke, though, when running, and seems to run just fine
). 8 fl. oz (1 cup) to 5 gallons is 80:1, so I would refill the oil tank with a measuring cup and figure out what ratio of oil to fuel has been burned ON AVERAGE over 10 gallons of gas.
OK, to my point. Since it seems to run so good with the extra 80:1 in the gas tank, and doesn't smoke, and it wets the plugs but doesn't foul them to a point where it interferes with the performance, should I continue using the 80:1 addition after my experiment is over?
