same MPEM
The '95 GTX 657X engine MPEM is a compatable change and works with the 717 (720) engine four wire stator
and flywheel. Just install the 720 motor, align it, and you will have no problem with the electronics. FYI: the
'95XP 720cc ALSO uses the 278000423 MPEM. A small 20 ohm adapter was added in the xp e-box to plug in
a tachometer just before the rectifier. You will have a 7k rev limit. You will have 5 extra pony's. (HP). Take
the opportunity while the engine is out to upgrade the fuel lines. I like Goodyear Red Stripe 1/4" (20') USCG
black fuel line. Disassemble & clean the aluminum fuel selector switch or replace it with a plastic one. Check
your RV clearance spec while engine is out, and paint the carbs after cleaning the internal filters, and be sure
to use Mikuni OEM kits & new needles-seats, pressure test the carbs AFTER re-assembling for the POP-OFF.
Lots of info in the HOW-TO section here on the above. If useing the '95 duals you will need to re-jet to
the '95 xp 720 carbs jetting specs, you didn't specify your carb preference on this build. A clean fuel
delivery is key to great performance!
http://seadoosource.com/impellerref.html Hope this helps!
