turbosl2
Need some help. My sea doo has 4 wire switchs which I believe are single pole single throw SPST for most of the switchs except the Nav/anchor light. My question is the wiring doesn’t line up with any switch I can find. Any idea what the 4 post is for with the resistor does? I would think these are 3 wire switchs with 1 lamp but the 4 post throws me for a loop. I will repin the connector if needed.
Wiring diagram
I purchased a handful of 3 wire amd 4 wire switchs. These two to be exact.
https://newwiremarine.com/product/on-off-spst-dependent-lamp/
https://newwiremarine.com/product/on-off-spst-indep-lamp-switch-body/
They are not momentary unless it’s for the horn or engine start. I am confused as to the wiring. Are the switches all supposed to be momentary amd the VCM activates the signal (e.g lights…)
I did not purchase this one.
https://newwiremarine.com/product/on-off-spst-lighted-switch-body/
Wish I had something to go by but the previous owner hacked it all up with automotive switchs amd not a single switch works. All a hack job. I want to put it back normal but don’t care if I have to repin
Thanks
Wiring diagram
Thanks
