96spxpos
First off,
I'd like to thank bob aka waterluvr for walking me thru tuning my carbs. That ski TOOK off so crisp and powerful that I was in SHOCK! They were obviously tuned wrong when I got the ski over 3 yes ago.
Anyway, put her in the water, even let it idle on the trailer (very low idle, needs to be turned up, no big deal) and it took on NO WATER it was great.. Idled to the beach front, took the seat off, again, no water.
Idled out past the no wake zone, and that thing zipped like a bat outta hell, jumped a few wakes, then decided to go to the shore and check. Took the seat off and water was pissing in from the carbon seal so fast.. I got it to the ramp asap. By the time I backed the truck up and loaded it, the water got almost to the bottom rubber of the battery boot, like right to the engine mounts..
Got it home cleaned it all out, fogged motor, all is well..
So, the engine is aligned EXACTLY how it was before and I had no leaks. This is an entirely new driveshaft rebuild kit and bellows, including a new PTO boot.
First, did I NOT pump enough grease into the zerk fitting to build pressure against the seal?
Also, are my hose clamps on the bellows screwing it up? (I know the bellows doesn't rotate, so I figured it's not a big deal)
And lastly, when I took apart the driveshaft, that half circle chrome c clip came out, and in the rebuild kit, there was no chrome c clip but a completely round rubber o-ring that I put into that groove where the c clip went (I think)..
Does that rubber o ring replace the c clip or does the c clip need to be in there as well? If so, than what's the rubber o ring for?
