The Mercury seal puller part number is 91-83165M, but you should be able to gently pry the seal out. Just be sure not to get in too deep with your pry tool or you risk gouging the surface where the seal sits in the housing. If you do, you may have to replace the stator. To reinstall the seal find a socket that is about the same OD as the seal.
Aaron:cheers:
