Hi,
I just bought '05 Speedster 200 with the 370hp SC engines. I've been reading my butt off trying to learn everything I can about these bad boys, and the ceramic washer thing has we quite worried.
Anyways, I am only pulling 6,500 rpm off the starboard engine (according to tach, but who knows how accurate it is), and 7,200 on port as WOT. It seems like it wants to push right (have to hold steering straight with a fair amount of grip or wheel will pull to the right).
I did notice when working on something the starboard throttle cable has been adjusted or worked itself loose, because the locktite bead is broken (port cable is intact). I'm hoping this is the case, and not a SC problem. But when looking at it, it seems the throttle valve is in the position on each side when levers are WOT. I did not see any markers that should be aligned though?
I wanted to see if anyone could enlighten me on a couple things.
First, what washers (link?) are the ones I need to buy for my 185hp SC/a side motors?
Second, I have worked on performance engines for ATVs for quite a while as a hobby (rebuilts, porting, polishing, milling heads, etc), but I adminitantly have no experience working with any type of blowers, in any capacity. Is this a job that is better left to those with direct experience, or is it a pretty simple procedure for those machanically inclined with a equipped garage? If the latter, can anyone recommend a good AZ based mechanic (I saw they can be shipped out, but I have a couple things I want looked at/worked on as well).
I heard the way to check if your SC was shot was to disconnect the intake and see if you could spin the SC impeller by hand. If so, it's done. Is this correct? And, if it is shot, am I risking serious problems while using the boat if the SC isn't spooling up until my parts arrive?
Thanks, and awesome forum!
Beez
Beez
