Low Comperssion-Is it time for a rebuild?
Ruff Cut
I did a compression test on my 20006 RXP 215 hp. It has 175 hrs on it. The SC was rebuilt at 120 hrs. Compression test came out poor. From front to rear-105-95-95. I was using a brand new gauge. It may be off but not that much. I thought about trying another tester. Does it matter test hot or cold? The ski runs great. Hard acceleration right to 68 mph. I do plan on rebuilding the SC this winter. But now may need to do the top end also. Any recommendations.... Thanks..
SC engines are a "low compression build". I'd have to look up the number to confirm what they should be.
And yes, ALWAYS try a different gauge when you have low ratings. We have seen it many times. Rebuild an engine just to have similar numbers after the rebuild. And then use a different gauge and the numbers are good.
My 185 sc got like 150psi... i do not remember seeing a compression test spec in the manual though, anyone know what it ought to be?
Compression can be all over the place on 4tecs, especially the sc models, and still run perfectly. A better evaluation of engine health is a leak down test.
Your valves or rings may leak a little bit when cranking but then seal up under higher rpms which gives you perfect performance.
If it runs fine, don't do anything. It is not like a 2 stroke where compression is everything. 4 stroke compression readings can be deceiving since knowing compression at like 200 rpms during cranking means very little. It's good for discovering catastrophic failure but not much more. Do a leak down test but I'll bet you get good results.
Average normal compression is 110 - 140 on scs but have seen them lower and higher and still run fine. Higher on NA models like 130-160.
