Lotsa oil in hull
thepotz
My 97 SP keeps getting lots of oil in the hull, (bout 1 gall) but I cannot find where it is leaking from? Checked for leaks around the tank but don't see any. There is a clear (now brownish) piece of tubing that connects to a 1-way valve on the right side of the hull but I don't know where it connects to? There is a one-way valve on top of the oil tank with no hose connected to it, is this where the clear hose is supposed to go? Seems odd that there would be 2 1-way valves in-line with each other. Anyone else w/ oil probs like this?
My 96 did this. Hose at the bottom of the engine that is the return hose (i think) had worn through at the hose clamp and dumped an entire gallon into the bottom of the hull. Easy fix. Not so easy to clean up.:(
Fill a 5 gal bucket, add laundry detergent, put in ski on trailor, drive aroud town, park at a car wash n tilt nose up n
pull the plug, take to home n rinse her out, nose up.
