Update: all fuel lines have been replaced, new fuel filter and the carbs have been rebuilt. However now I have a new problem. No fuel is getting to the carbs. Not ever getting to the fuel selector. I replaced all the lines one by one to avoid any chance of mix up. checked the fuel selector valve and all looks good. none of the lines to the selector smelled of gas so it seems like it may be a problem with the pump which was working fine before this whole endevor started. If i pour fuel directly into the carbs it will run for a few seconds but of coruse die one all that fuel is sepnt. I did notice one of the check valves on the hull does not seem to open under pressure (applied by motuh not sure if thats enough pressure or not). Also there is another valve on the hull right next to the check valve, its kinda red/orange and has a hose that runs to the back of the ski but is not connected to anything. Any thought are greatly appreciated
