So I finally get a day off work after working 17 days in a row. I head to the lake with a buddy today. I push the left button and it wont start.
I get the 2 beeps, the shifter is in N. The right engine fires up fine. When I push the left start button, I hear a faint click but no slow cranking or anything.
The small box mounted next to the engine is where I hear the click. I took the cover up and off and I am guessing that is the solenoid. All connections were tight there. It clicks when you push the button, so I guess the solenoid is working.
I have only had the boat out once. Everything worked fine that day. I even came home and started it to flush it out and it was fine. The only thing I have done since is I looked around in the engine compartment to see if the 2nd battery was going to fit, I did not move anything or disconnect anything. What do I check now?
