Hello all, as I am new to the Seadoo world, can any of you experienced guys tell me why water is seeping into the engine compartment via the driveshaft of my 96 XPS.
The problem started when I put the seadoo in the water after a two year shore leave and I planned to lube everything up at the dock. When I pulled the seat off, I noticed a broken gear clamp on the drive shaft seal.
Please confirm, should the seal (with the grease nipple) rotate on the drive shaft? Well it slides up and down the shaft but it can't rotate. Also the second pic shows what I believe is the remaining portion of a hull seal connection? Am I right or do I have the intended arrangement all wrong? ie. am I looking at removing the impeller and inserting a new hull seal?
Thanks for any help you guys can throw my way.
