biffdotorg
So we have a great weekend this week, and we are out on our second night of surfing behind our X20
I have a full boat, and a surfer in the water. I go to fire up the engine and it does nothing but crank. It's like the spark is cut as it sounded like it wanted to fire. I had no idea what to do as the engine was hot, and has run perfectly this season as it has in the past.
I had to assume it was electrical and started with the kill cord. I took it off and replaced it with no luck. I pulled it and pressed the kill switch button manually while cranking and it actually changed the sound of the cranking. By this time it may have been a little flooded if that is possible.
So I replaced the kill cord after hearing that change, and it fired right up. Is it safe to assume that button the kill cord is attached to may becoming corroded? If I don't want to hot wire it, can it be cleaned or lubricated? I could find a replacement part, but don't want to do that if it can be cleaned.
Thanks guys!
Thanks guys!
