hexec
At the end of another amazing time on the lake my 97XP800 began to behave very poorly. The motor rev'd and responded nicely but the ski didn't hook up. Once I got the ski up to speed it did hook and was better for a while until you slow down. It seemed like the impeller was not spinning with the drive shaft. I knew that was not possible.
I found the jet pump cone was cracked along the rim and it lost all of the oil and burned the thrust bearing. It had totally exploded and damaged the pusher. The impeller was slopping around about 1/4" back and forth on the shaft. I figure this was causing the severe cavitation I experienced on the lake. I want to replace the 2 inner bearings, thrust bearing and washer, pusher, spring, and cone. I'm sort of a noob, not sure what to expect with this sort of job, comments or suggestions.
I've been told that the pump might be toast. Without taking it apart and seeing for myself, I find it hard to believe that a bearing failure caused so much damage.
For now, I purchased a rebuilt pump but I'd like to repair this one and keep it as a spare. Should I bother?
