MoDawg73
Hello all,
In the course of rebuilding my 99 GTX Ltd, I pulled the jet pump cone off, and out came a couple of ounces of water, separated from some really black, icky smelling oil.
I am trying to figure out if the pump needs to be rebuilt, because I don't have a press to do it with.
I pressure tested it, and it was at 8 PSI after 10 minutes. I know the manual says it should hold 10. Now when I tested it, I had not applied any loctite on the cone o-ring, which I had planned to do when re-assembling for good.
What do you guys think? Do these symptoms warrant a complete rebuild? I sprayed some soapy water around the cone and the fitting and found no bubbles.
If I decide to not rebuild, what are the realistic risks that I face?
If I decide to rebuild, should I install a new wear ring as well? It has good clearance (Around .7 MM), but I am not sure how far into the useful life that would represent.
Thanks for any wisdom you can pass along!
Ken
Ken
