Sportster-2001-951C-Stock
Well I think we are getting closer. So this morning I checked the battery. 12.8 volts. Unplugged power from computer and checked voltage at front of the jet ski. Only 4 volts. I then jumped it at the solenoid and it started right up. My thinking is there is a bad wire somewhere after the solenoid and before the MPEM.
Hi, I would agree there is probably a bad wire or connection somewhere between the solenoid and MPEM.
This is a process of elimination, so if you jump the two large posts on the solenoid and the starter cranks the engine, it rules out the battery cables and starter.
If you measure the voltage on the red (output) terminal of the regulator/rectifier, and measure some value less than the battery voltage, it confirms there is an lose or corroded wire/connection somewhere between the regulator output and the battery positive terminal.
Once confirmed, then it's a process of working back towards the battery from there, until the voltage is found, then narrowing it down from there.
So yes, we suspect a lose connection or corroded wire somewhere but there are two sides to the electrical system, the positive side and the ground side, so we have to check both of these. Most of the wire, and the fuses, are in the positive side of the wiring harness, so most likely that's were the problem is, however, the grounds are often low in the bilge where they connect to the engine block, thus can corrode due to the wet/hostile conditions.
I'm quite certain the problem is a simple one and once located should be an easy fix, we have no indication of any major parts being defective based on the info collected so far.
So, please find the red wire on the rectifier/regulator and measure the voltage from there to the battery negative terminal. If 12V, then also measure from red wire to engine block, this should also be 12V.
