Is there anything wrong with SBT pump housings and wear rings
peanut8474
Is there anything wrong with a new SBT pump housing and wear ring and remanufactured impeller or would i be better off to buy a used sea doo housing since I already have a rebuild kit. They will both be around the same expense
If I were you i would at least get the oem wear ring. The housing and impeller should b fine from.them and like Lou said the usually warrinty there things for a year. Which I'm.sure just the housing
