ah64driver2002
I am working a first time ever rebuild on my 96 gtx. Doing a top end rebuild due to rave valve failure. Pulled bottom end to ensure the half of rave valve I was missing wasn't still in the engine. Anyways my question is in the attached pic you might be able to see a foam seal around the round opening for where the jet pump mounts. Is this supposed to be there? I can't find it in a parts diagram. As you can see it doesn't seem to be bonded on correctly. Just tying to figure out why it's there or how to fix the issue. Or what the issue might be if it's not supposed to be there and I remove it before installing the pump. Thanks for any help with this
